In the ever ongoing saga of life....the dishwasher taking a crap, punching the ice maker because it pissed me off and ripping it off the freezer skin, BAD TUB decided to start running like doody....
Symptoms...
1) low oil pressure at idle....so I started using straight Valvoline racing 50 weight. Problem gone....
2) transition issues from idle to WOT, stumble an a roar....cranked up the boost...WTF, right?
3) low boost, noise when cold...pulled valve cover and found head stud bolts in covers...oh CRAP.....
4) Torqued studs on bottom to recommended specs, went up top did those, came back and the lowers were loose again......
Pull the engine time....geez, picked the wrong day to quit smoking Crank.....
Engine torn down....the four puck clutch was too heavy for the application and hammered the end seal, screwed up the bearing and galled the oil passages, low pressure flattened the cam and took the lifter with it....ya think the burnouts had anything to do with it????
Ordered a stock style clutch disc, new PP, and TO. New studs from CB Performance that are specific to turbo applications and hopefully won't stretch, new head shims, cam and lifters....should have it back together for $800ish including the align bore....did some clean up on the heads...the exhaust guides were a little loose so redid them. Good thing, they showed no evidence of pinging or any other damage...
Dishwasher...$260. Sears will warranty the freezer....
Life is getting better....
