Dumb question: How do I stop the "Taco" plate from leaking? It's not a sending unit plate, just a plate. It's flat, new o-ring, new crush washers. Still seeps a bit.
URY914
Jan 31 2004, 06:30 AM
Drain the oil from the engine.
Paul
DNHunt
Jan 31 2004, 06:42 AM
Whatever you do don't tighten it too tight. It will bend and then it's impossible to seal. Next time you have it off check it to make sure the mating surface is level.
Dave
Jan 31 2004, 11:18 AM
QUOTE(DNHunt @ Jan 31 2004, 04:42 AM)
what he said ^^^^
plus, put some sealant around the o-ring and around the 2 bolt holes before you put it back in ...
Andy
