1975 914 Red Exterior/Black Interior - $5000 located in Keyser, WV near Cumberland, MD
Interior - Black - the dash has a couple small cracks as well as the drivers seat - after market radio - Odometer reads 85683 - dash has 2 toggle switches, 1 is for the fuel pump.
Exterior - I think this is the original paint - its rubbed thru on a couple corners on the rear trunk . couple surface rust areas, no sag - the door gaps are very parallel. Tail light lens are cracked. Windshield trim needs installed and is available.
Engine is a 2.0 with 40 IDF Weber carbs - runs good - transmission is a side shift and does have a popping out of 1st gear problem. New battery tray and some surface rust on the drivers side hell hole.
Front sway bar - rear sway bar but not hooked up on ine side
Tires are new EVO.
Car is located in Keyser, West Virginia close to Cumberland, Maryland on rt 68. I could help transport car within reason for $1.50 per mile loaded with a non refundable deposit of $500.
Bill Smith - 304-788-0248 or wispskibum@verizon.net
