I have a new to me /6 project that I am starting. I am trying to get everything working decently so I can determine what will need to be done to make everything right. This is a 2.4 w/CIS. Here are the problems I am having.
1) Hard to start when cold (I need to give it gas) and won't start after it gets hot. I am assuming this may be a fuel pressure issue. So, Is the #1 circled part the pressure regulator? I know #2 is the warm up valve. I am having problems understanding how the warm up valve operates. Where would I want to check the fuel pressure (where would I install the gauge)?
2) The second picture shows a switch that the PET only calls "micro switch". What is that for? The car will stutter when I give it throttle as the switch closes (or opens?). Thanks for the help.
