QUOTE(davep @ Aug 12 2008, 10:12 AM)
Well, that is not a very early engine, so I'd have to guess that the seals were added at some point during an engine service.
You did mention in one post about needing the early small pushrod tubes. Were those heads on this engine?
Hi,
Cool, I will leave the stem seals off on this build. My valve stem clearance is very good, so it should not draw too much oil.
My other forum is for small push rod tubes. I bought a pair of "freshly rebuilt 1.7L 914" heads in CT last year. I do not know the history of these heads, but they are the ones that require the smaller push rod tubes. (They did a nice rebuild - new valve guides, new valves, ...)
If it comes to it, there is enough metal to mill them out for the "stock" push rod tubes. I just hate to pull them and cut them.
Thx,
Neil
