Hello, I'm getting ready to install the carpet I got from morph into the car. Can anyone tell me where it's glued and where it's not? I can't tell by the old junk that came out of it.
Thanks, Chris
dr914@autoatlanta.com
Aug 11 2008, 04:36 PM
QUOTE(hitbyastick @ Aug 11 2008, 03:25 PM)
Thanks, Chris
rockers, left wheel house, rectangular piece behind the wooden pedal board, pass bulkhead only the rest lays in the car we use spray trim adhesive
TravisNeff
Door sills, front bulkhead (driver & passenger), the rest is not glued. Use 3M super 77 adhesive, spray & wait till tacky then apply.
The only tricky part is the driver side sill with the ebrake depression - you'll need to stretch the carpet to press in and I would recomend you spray both the sill and the carpet and wait until really tacky then apply.
hitbyastick
Aug 11 2008, 04:44 PM
Thanks for the quick reply. That's what I needed to know
tod914
Aug 11 2008, 05:17 PM
You really don't need to glue it in. The side pieces are held in by the threshold plate screws. The front side pieces are secured by the speakers. Easier to get out in case you need to clean them.
rjames
Aug 11 2008, 05:21 PM
hitbyastick
Aug 11 2008, 07:12 PM
QUOTE(rjames @ Aug 11 2008, 04:21 PM)
Does the threshold plate grab the door seal as well?
boxstr
Aug 11 2008, 07:34 PM
I agree, don't glue anymore than you need to. The threshold plate will enough to hold the side carpet in place. The plate also fits over the seal. CCLINCARPETERIA
