QUOTE(r_towle @ Aug 11 2008, 04:44 PM)
I was speaking with a guy who has one yesterday.
He mentioned that the early ones are becoming hard to find certain parts for.
Just check to see if you can find all the parts...still.
Rich
Main problem with the early ones ( 85.5-86) is the suspension is slightly different. Narrower offset but the later ( 87 on ) can be bolted right on. Other than that the changes are negligible.
BELTS BELTS BELTS. If you don't have a receipt showing it done within the last 30,000 plan on doing it IMMEDIATLY. Always replace the water pump with the belts and DO NOT try to do this without the proper tensioning tool. Some will tell you it's o.k. on an 87 on car because they have a spring tensioner...well they do on the timing belt ONLY. The balance shaft does NOT have a spring tensioner and you still need the tool to set them up. DO NOT think you can do it without the gauge, you will most likely fail, and it may take sveral thousand miles to know it, but one day the balance shaft belt WILL let go and wipe out the timiong belt and then the valves go bye bye, if your really lucky the pistons will survuive
Not trying to scare you off just trying to provide you with ACCURATE info. I'm no expert but I did stay at a Holiday Inn once
If you get an early car and want a little more power, find a 26/8 turbo, add a MAF setup,wastegate, exhaust, chips blah blah blah. Check out Lindsey racings site, they have a decent BBS as does 944 online. You can learn alot if you have the time to wade thought the newbie dribble
