QUOTE(kwales @ Aug 14 2008, 09:41 PM)
Try Sears or a real hardware store. My Sears tool store has a tray of assorted brushes. If you can't find the one you need, buy closest oversize and file the carbon down. It's soft, easy, and messy at the same time.
If it's generator brushes for a VW beetle, you drill a hole in the side, push the old wire braid through and secure with solder.
Ken
Thanks for the Sears tip. The fresh air motor brushes are fairly small - about 5mm x 6 mm. I just looked at over 600 brushes on Amazon.com, but none the exact size. So filing larger ones down is probably the quickest way to get this thing done with.
Paul
