QUOTE(skeates @ Aug 14 2008, 01:19 PM)
My plan as of right now is to encapsulate the whole car in a magical rust-preventing shell of POR-15 and I was considering using their "tie-coat" primer given that it is specifically designed to adhere to the POR-15 undercoat.
I think that this is an idea that many of us have had, and then eventually decide is totally overkill. Rust issues simply don't affect many areas of the car, unless you plan on running it in salt water. Once done with your resto, you should be good to go for another 30 years - provided you take a little care of the car.
The main issue is that POR does not seem to live up to its claims.
As a test, I painted a sort of rusty tin lantern in POR 15 following the instructions and using all the products (metal ready, rust converter, POR 15 silver paint) and hung it outside on a hook for decoration. It looked great for a year. Year 2, I noticed some area where there were rust bubbles. Its now in its third summer, and large sections of the POR-15 paint is peeling away.
Once you get your rust issues solved, and the body painted, you should be okay. That said, coating prone hi use areas of the car in POR-15 can't hurt. I did my floor pans with it. For the underbody, I used several coats of Eastwoods Chassy Black epoxy paint.
Zach
