QUOTE(Tom @ Aug 14 2008, 10:06 PM)
Had a similar problem and it was one of the round relays. I could wiggle the relay and the wipers, horn would work until I hit a bump, then wouldn't work again until I wiggled the relay. Finally got tired of it and got a new relay. End of problem. If you have the Haynes book, you can trace out the power path and see which relay it is. It is energized when the switch is turned on. J12 comes to mind, but I can't be sure without the manual in front of me. I think this relay allows power to the fuses for the horn, radio, wipers and maybe headlights. Basically everything that requires the key switch to be in the on position.
Tom
Thanks Tom. Do you remember which relay it was and where it is located? I have swapped the relays on the fuse board with no luck. It seems strange that all of those things, i.e., horn, lights, fan, wipers, etc., would run through the same relay.
I am trying to follow the wiring diagram (spaghetti soup to me). I can't figure out how all of those go through any one relay, that's why I am wondering if it is the ignition switch. But then, if the ignition switch is bad, why does my fuel pump, gauge lights, and parking lights come on when I have the switch on?
Does the ignition switch have multiple contacts that feed the different relays?
Help guys, our Wisconsin summer is short enough without taking the darn thing off the road for a few weeks.
Thanks.
Warrenoliver
