HeloMech
Aug 14 2008, 09:14 PM
I thought on my 73, it was just behind the backpad, mounted to the rear firewall. Now, in my 70, I have a newer backpad so I pulled it forward to look for the reel mounting hole.
So then... WHERE'S IT MOUNT? Is it on the side below where the upper 'loop' for the seatbelt mounts? The driver side has a 4pt harness so it's no help!
Thanks!
Zundfolge
Aug 14 2008, 09:15 PM
70s don't have seatbelt reels, they have fixed belts that adjust a bit.
Rusty
Aug 14 2008, 09:21 PM
Yessir.
No reels on a 70. Fixed belts that are adjustable in two places... across the chest and across the lap.
HTH,
Rusty
jim_hoyland
Aug 14 2008, 09:52 PM
One less thing to go hay-wire......
Gint
Aug 14 2008, 10:08 PM
I prefer early belts. PITA for an ever changing passenger, but great for the driver. No crappy 35 year old reel to hang up.
markb
Aug 14 2008, 10:16 PM
I've used the rear belts from a mid 80's Volvo station wagon that work great. They mount beside the seat in the normal bottom mount spot. I have an extra if you need it.
HeloMech
Aug 15 2008, 09:19 AM
So the later model reel version doesn't have any place to bolt up to then? DOH! Guess I have a spare of those then... Guess I might have to bolt in another helicopter seatbelt...
Joe Bob
Aug 15 2008, 09:42 AM
If you have a guide bar for 4/5 point harnesses, mount it on there....I did with the Rocket.
BTW, youse guys with the old seatbelts? New AX, DE and TT rules dictate that even STOCK classes that allow for use of three point belts? 20 years is the max life.....so re-web or replace.
Aug 15 2008, 12:20 PM
QUOTE(HeloMech @ Aug 15 2008, 07:19 AM)
Correct ...
I am very happy with my early, non-retractable seat belts. They work just fine, can be easily adjusted for length and hold you schnugg in your seat. No fiddling with a reeling mechanism that NEVER works right in any 914 I've ever been ...
Andy
HeloMech
Aug 15 2008, 01:29 PM
So where do I get one of those jobbies? I have a retractable spare with all hardware I guess... lol
Maybe a better question. Where do I get the guide bar for the harness that mike mentioned? Then I can just add another aircraft harness and be happy shmappy
ChrisFoley
Aug 15 2008, 05:21 PM
We did this to install inertia reel belts in a customers car recently:
