QUOTE(LetoAtreides @ Aug 22 2008, 11:20 PM)
Dellorto:
main jet 36
Venturii 140
Ahhh - no.
Those aren't credible numbers for those items, sorry.
There's at least 3 sizes & flavors of Dellorto. We need the size of the throat barrel; it'll be in the casting on one of the sides of the carb.
36 might be a credible number for a venturii; with luck, you'll be able to see it as a casting number on the top - you'll need to look into the throat, under the throttle butterfly. With no visible size you have to measure. An accurate measurement involves taking off the top of the carb, but it's not that critical so if there's no number and you can't eyeball it with a millimeter ruler, don't stress.
But we do have to know the numbers for the mains and idle jets. Knowing the number on the air correction jet would be a help down the line.
I don't know the rest.
Find out. If you're not sure how to find out, ask. I last tinkered with a Dellorto-carbed 1,7 30 years ago, so there's a bunch of stuff I've forgot, like -exactly- where the jet carriers are. I could recognize them if I saw one again, but i'm not going to be able to tell you something like "right side, 10mm, near the center." I know there are guys here who've got Dellortos and maybe they'll be able to tell you exactly how to pull the main and idle jet carriers. Or get some really good pictures and we'll go exploring.
But it's important.
They came with the car and worked perfectly on my old engine, so I don't know why they're acting up now.
Since you have a '75 it didn't come with a 1,7 so right away there's one big difference. But it doesn't matter. _Something_ is wrong.
Plugs are as follows:
1: black
2: brown
3: black
4: brown
The exhaust does smell a little rich and has some smoke when the car is first warming up.
the popping seems to come from the 1-2 carburetor.
I fixed the whistle! Just had to tighten the nuts that hold the carb to the manifold.
After that, you checked all the carb and manifold hardware, yes ? It's impossible to tune an engine with big vacuum leaks...
intake popping is often associated leanness, but your other symptoms are showing incomplete combustion.
What kind of plugs - brand and heat range number?
You're -sure- you have good plug wires and the plug connectors are all on snug?
When you tested the spark you got a nice fat blue spark?
(We're making sure the primary systems are working because most carburetor problems aren't - as witnessed by your observation that they worked on a previous engine, and because you have conflicting symptoms - it acts lean but is showing obvious incomplete combustion - poor ignition can cause this...)
Do this - taking good notes:
On each carb throat, make note of -exactly- how far out the mixture adjustment screws are. Do this by gently screwing them in and counting the quarter-turns until they bottom. They -should- all be pretty close to the same. Then, back them out again to where they were, only a half-turn less. See what if any difference that makes.
What grade of gasoline are you trying to run? 1,7's - if yours is still all-original - have a little higher compression and might benefit from a midgrade - but probably doesn't require premium. Wait - you're in CA, where the octane numbers don't match the rest of the world. Try midgrade.
