QUOTE(dlestep @ Aug 19 2008, 05:59 PM)
...Does anyone know the nominal angle between the spindle and the strut centerline? I don't want to have to run with 2 to 3 degrees of chamber if it incorrect.
The Haynes is useless - they tell you 'take it to the dealer but if it hasn't been in a crash it'll be OK.
The Official Porsche 911 Factory Workshop Manual says "assemble the strut into special tool P.286" - after which you verify that it's OK in toe and camber.
So - *somebody* probably knows what a new strut uses for a kingpin inclination angle, but it is not specified
per se in the WSM.
However - figure toe is (essentially) infinitely adjustable which leaves you with camber, which is (relatively) hugely adjustable for a street car. (Race guys keep looking for more negative...) There are 'more' adjustable top bearings available (usually so the race guys can get more negative...) if you're unhappy with just elongating the factory slots a teeny bit, which is what we all did before the spiffy top bearings were available.
Then, too, there's Elephant's tricko offset ball joint, typically used to provide additional negative for the race guys, but I don't suppose there's any reason you couldn't flip 'em around if you needed an additional degree or two of decamber.
IOW - unless you have some reason to believe the car's been radically curbed (how are the bearings?) or lept off a cliff you should be OK.
They should be the same right-to-left so if they're different, you may have some minor cause for concern, but otherwise, go find yourself a dealer or independent with a P.286 or wing it.
Or maybe someone with proper angle-finder tools has had access to a known-new strut and can post the real kingpin inclination angle...
