A thousand apologies for not posting pictures sooner!!!
There were a couple of problems with the panels. I've talked it over with George, and he's considering some fixes for the next runs.
Realize- I have one of the first seven sets shipped. My pain will be your gain.
OK- here's the story-
The top and bottom flanges were cut kinda wavy. Along the top edge, it's a bit too visible there in the door jamb, plus some of the mounting screws would break away where the flange waves out too far. The flanges are cut as a secondary operation. I told George that I'd just as soon cut them myself- send me the raw parts. I can take whatever time I need to make it fit MY car.
Second- the right front flares out a bit too much for my car. It's similar to the 916 and some of the M471 cars, since actual factory parts were used to make the molds for these.... Not sure what my solution is here yet.
Third- there's a smooth square area where the jack hole plug needs to be cut out. Well, it wasn't in exactly the right place for my car. I suspect that there's a lot of variation in the fore-and-aft location of the flare across all the cars that got them. My jack hole needed to be about 3/8" farther aft than where the smooth area is. I cut it where it needed to be, and the plug covers the disconnect, but I recommended he NOT PUT THE FLAT SQUARE SPOT AT ALL. Someone could cut it and then find out it wasn't right for his car....
Overall, though, these are the best starting point for flared rockers I've seen....
(GRRRR! It's only letting me do two pictures! I'll do more in a second post. Probably has to do with the willow green skin getting screwed up!)
You can see the wavy cut along the bottom flange in the first pic, and the jack hole spot...
Click to view attachmentClick to view attachment
