Guys,
Here's a topic for open discussion that I haven't seen discussed here before.
As many have known over the years, I have a 1970 914/6 that I restored and upgraded w/a '95 model 993 3.6L engine.
As I was putting the car together, I bought a engine to chassis wiring harness from Patrick Motorsports to marry the engine and chassis together. The harness was a good quality product that went in very cleanly and easily. It was really a plug in installation. The only anomoly I noticed in it was a that it came w/a wired in OBDII access plug to read the DME.1995 is OBDI. I really didn't give it much thought, cause when everything went together, the car ran fine. And it has for the past 3 years now.
Flash forward to 2008. The car recently started running crappy after it warms up.
I now need to read the system to retrieve the fault code.
my question thus, how has you guys hacked into your system? I know that there are a lot of conversions here.3.2L's,964 3.6's,993 3.6's, and 993 Variorams.
here is what I have done thus.
1. I've been in touch w/PMS, and they are working to address this.No issue w/vendor.
2. I have used my scan tool to try communicate w/the DME.It won't communicate,because all modern scan tools are OBDII,1996 + up vehicles only.One error msg is ''can't communicate,engine may run but not be OBDII compliant.''Scanning option is out.
The only option I'm beginning to keep falling back on is a Porsche only dedicated software package from Durametrics that does advanced Bosch Motronic trouble shooting on ALL Porsche vehicles from 1990 thru 2008.It's about $700.00
this would require loading the software on a laptop, and getting a 1995 911 diagnostic access plug, and pig tail it into my wiring harness.
The only option i will not take is to hand the car over to a Porsche mechanic,and write a blank check.
Give me some out of the box ideas guys.
Ron
