DrifterJay
Feb 1 2004, 10:42 PM
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2456677544has anyone used this..not that I am doing this swap...just curious if this is a piece of shit or not?
Jared
might be usefull to someone else..
Qarl
Feb 1 2004, 10:46 PM
It is NOT recommended.
Get the one that welds to the bulkhead.
The quick six uses the factory (4-cylinder) mounts, which can weaken or tear, as the 911 motor is significantly heavier than the 914 motor.
Look at what the factory did and then realize that they had their thinking caps on!
Joe Bob
Feb 2 2004, 12:25 AM
They suck...bulkhead is the only way to go.....
Eric Taylor
Feb 2 2004, 01:26 AM
Yeah that's crap. Weren't they know to colapse(sp) or something horriable?
Dave_Darling
Feb 2 2004, 10:38 AM
Collapse? No, that's the pretty Patrick bar. This one is beefy. As in, 50 lbs of iron beefy!
If you have heat exchangers or a side-shift transmission you will be using on your Six, you will have to cut the mount bar or the linkage/exchanger.
Bulkhead mount--mo' $$, but mo' bettah.
--DD
larryp
Feb 2 2004, 01:49 PM
It sold. Wonder who bought it.
(By the way, Dave, I had heat exchangers on my car with that mount with no cutting req'd.)
Eric_Shea
Feb 2 2004, 01:56 PM
There was a weight transfer issue as well. Bulkhead mount places the weight of the engine further forward no?
larryp
Feb 2 2004, 09:50 PM
Weight transfer? No, either none, or insignificant. But there is a bunch less gound clearance.
Steve
Feb 2 2004, 10:28 PM
I ran the MSDS quick six bar with a 2.7 for over 10 years with no problems.
BTW the MSDS bar would not work with the stock heat exchangers.
But it worked fine with headers.
Back in 86 the only choice was MSDS or stock six mount.
I was told the PMS bar would work with factory heat exchanger. It didn't and it also sat much lower and scraped on speed bumps. I quickly sold it and switched to the Richard Johnson center mount so I could use my heat exchangers.
I also cut off the 4 banger mounts to give me more room to adjust the valves.
BTW who makes that bar on ebay??
I have never seen one like that before.
Just curious....
Steve
Eric Taylor
Feb 3 2004, 12:35 AM
Yeah, dave I was thinking the patrick bar. What's that made out of?
Eric
FlatSix
Feb 3 2004, 08:56 AM
I'm using one of these bars.
There is a reduced ground clearance issue, but as Dave say's it's beefy (& heavy). Doen't look like it will fail.
I have standard heat exchangers (on a 2.0 litre) and a side shifter so I did have to modify the linkage bar, but not the heat exchangers.
I got mine from AA... They did supply it on time without any fuss, this was in the mid 90's.
