lonnie152
Aug 25 2008, 09:37 AM
working on 1974 car. passenger seat belt keeps sticking so it only wants to pull out an inch at a time. passengers are getting frustrated.
do i need to replace or is there a fix. many thanks.
dr914@autoatlanta.com
Aug 25 2008, 10:57 AM
remove the backpad, then pull the seatbelt out all of the way, then lube the pivot at each end with the penetrant that turns to a light grease and work the belt. It will be just fine again.
r_towle
Aug 25 2008, 10:58 AM
To add.
After you pull the belt all the way out, before you add grease.
Blow the housing out with air/shop vac it...its full of years of dust and dirt.
Rich
roadster fan
Aug 25 2008, 12:52 PM
QUOTE(r_towle @ Aug 25 2008, 09:58 AM)
To add.
Rich
you should have seen the ones I pulled out of my 73' Yikes
Jim
PRS914-6
Aug 25 2008, 01:04 PM
After many tries, I figured out a method for tightening the factory seat belt springs. It would be difficult to explain and takes a wee bit of luck to prevent the spring from flying everywhere. The belt material can't be too old and crispy. I can rewind yours for a reasonable cost. PM if interested.
lonnie152
Aug 26 2008, 09:51 AM
Many thanks to all who responded. It is a great help to have your support and i will get about fix directly.
