how can i run a fuse box so that when the ignition is in on position everything running off the fuse box will turn on, but when you turn the car off, it kills all the power? The reason i ask is bc i want to run a new fuel pump in the car but want a fuse for it, but i don't want the thing running all the time, that wouldn't be good at all. Does the stock fuel pump go through a fuse, if it does which one is it? Thanks everybody, with this last bit of help the car will be running today(i hope), not driveable, but i'll get to hear it run again
