QUOTE(championgt1 @ Aug 27 2008, 07:53 PM)
QUOTE(SLITS @ Aug 27 2008, 12:37 PM)
Python Injection in Stanton, CA rebuilds them. Fuel Injection Corp in Sacramento?
Buy, the later ('75 - '76) single in/out pump ... there is no need for the three titty one.
or
Buy any roller pump that puts out sufficient pressure / volume .... the car doesn't care .... only Pat does.
How does that work? Do you just run the return line back to the tank and not to the pump? Do the two ports on the pump take the feed line from the tank and the other port has the line that runs the fuel to the engine? Does this make any difference if the pump has been moved up front?
(sorry for the hijack)
The third tit on the stock pump was a pressure relief that was Teed into the return line from the fuel system pressure regulator .... so, you are correct .... you just join the line from the pressure regulator to the return to the tank.
If you move it up front, the same applys.
And an electric pump works best as a "pusher" not a "sucker" so mounting it below the tank, near the tank is a good idea .... flooded suction ya know.
