Nick
Aug 29 2008, 05:04 PM
Trying to replace Bilstien inserts on my 911 SC. Left side came out easy. Right side won't budge. Any ideas on how to get this thing out?
Nick
r_towle
Aug 29 2008, 05:10 PM
Is there a roll pin at the bottom???
Rich
Nick
Aug 29 2008, 06:04 PM
QUOTE(r_towle @ Aug 29 2008, 03:10 PM)
Rich
Roll pin has been removed
J P Stein
Aug 29 2008, 08:06 PM
Frankly, it's been a while since I've BTDT, but IIRC, there is a hole in the bottom of the strut (smaller dia above the ball joint shaft hole, in line with the inner rod) that you can slide a drift pin thru to tap the inner rod loose.
