Hi guys
Looking to save some weight out of the late doors (i.e. the ones with the iron gurder in). I already have perspex windows. I can't go fibreblass due to regs. I don't want to put early doors on there as this would mean finding a good set over here in the UK (which is a problem) and then having to spray them up - a route I really wanna avoid. Therefore I need to lighten the doors I've presently got on the car. I also need to keep the winder mechanism. Is it even possible to cut that impact bar out of the door without having to cut all the winder mounts out of the door and/or the cutting/grinding affecting the paint on the outside of the door (wanna avoid getting the spray gun out if I can help it).
Now I could just start attacking it- this is my usual practise - however before I do I though it would be a good idea to find out from all you racers how (or if) you've lightened a set of late model doors before. Any pictures of them lightened up so I can follow in your footsteps.
Also, whats the best method for removing all the crappy tar from the floor? any tips. Tried to get some off today, couldn't see any obvious easy ways to do it. Looks a real messy and long job. How much weight does this actually save anyway, after all that hassle.
