QUOTE(Wilhelm @ Sep 2 2008, 05:42 AM)
I am in the process of stripping (sandblasting) my car to the bones and I think it must have won the "Let's see who can slather the most seamsealer into das Porsche?" contest at the factory. As I sand blast and dig out kilograms of seamsealer I am noticing rust especially on the bottom seams of the car where seam sealer has sealed in water and in area where the stuff is gobbed on under the wheel wells, especially the fender seams. My thought is that teeners collect water through open windows, leaking windscreens and worn out top seals. That water runs down hill and would leave the car in many instances except that goes through the metal seam only to be stopped by the externally applied seam sealer and is trapped in the vehicle. I'm thinking of primering all surfaces I can reach with epoxy primer then spray on bedliner on the inside floor of the trunks, floor of passenger compartment, gas tank compartment, and inside of the wheel arches in continuous panals so there is no edge for water to get under. I am also thinking of placing some self draining rubber valves (those soft thin wall floppy kind) in areas like the trunk or under the seats to help water exit. Basically as they say in the construction business I'm trying to think like a raindrop. Thought anyone????????????????????????????
couple of thoughts, some if which I have heard from alot of the 356 guys.
First and foremost...the car is 35 plus years old now.
Be thankful they DID use some sort of undercoating or else it would have rusted more...
Water can and does run uphill, even more than you think in a car...its wicks up the seams into the car. Condensation forms inside closed cavities and gets trapped in seams that are/were bare metal...the best you can do is deprive the area of air and hopefull slow down the process of oxidization.
I would suggest you open up every joint, clean it out and reseal it for the next 35 years...use new chemicals, but dont rely just on piant...its to weak of a top layer for the underside of a car.
Wheel wells and the bottom of the car will see ALOT of dirt and never ever see you waxing or cleaning it...just a fact of life. Rocks chip paint...exposed paint will rust fast.
The one word of advice I got from a 356 guy was so to the point.
Once you are done restoring this car, it will never get restored again. It will be done (provided you do it right). It will never see the neglect it got in its first part of life because of the cars classic collectible nature.
It will live inside, it will get waxed, it will be kept ALOT cleaner than it ever was in the 70's 80's or 90's.....
So, whatever you choose to do will be cared for and kept in good condition...dont loose sleep over it...
If you put no undercoating and no seam sealer you are asking for a short life on the car. All cars need seam sealer, just do a good job and make sure the drain holes in the longs are kept open.
Rich
