QUOTE(Root_Werks @ Sep 2 2008, 01:26 PM)
QUOTE(Cap'n Krusty @ Sep 2 2008, 01:17 PM)
Cork. I use a thin coat of "Gasgacinch" on both the cover and the gasket, let'em air dry, and slap'em together. NEVER any sealant between the gasket and the head. No RTV, either. It promotes leaks, and rust, too, for that matter .................
The Cap'n
I do the same thing, works like a charm.
In addition I put a thin layer of Swepco moly grease on the head side of gasket. It keep the gasket from sticking to the head, making the next change easier (no scraping old gasket off the head). If I need to pop a valve cover off to check a valve/rocker/return tube/etc... they don't usually leak when put back on. Not an excuse to reuse old hard gaskets but if I am chasing a problem or noise I can replace the gasket with a new one after I find then issue.
I never though of the rust issue with RTV but I don't use RTV for much anyway.
Jim
