UPdate:
Pulled the drivers side axle, the outer CV cage has a couple of cracks. Gues they forgot to replace this side when the trailing arms were rebuilt. I thought the sound from a craked casge would be louder and constant. Anyway, should be done in a couple of hours. Turned out to have supressed a lot of the sound, but I still hear it when braking a low speed and driving slow on uneven pavement. Almost replicated the noice by giving a sudden push from rear of sail panel. Gonna need a second pair of early to track it down.....
Originally:
I have sound that comes from behind the driver seat, usually at low speeds, esp during stop.start over irregular surface. It's random. The CV is new, as well as the trailing arm bearings.Never hear it when the car is up to speed.
It sounds like a stress-relieving creek, maybe like something tapping the rear firewall.
I finally duplicated the sound in the garage with the car parked. If I push up on the driver side HE and push back down on the rear fender, it makes the sound.
I'm thinking motor mount. but they are less than two years old. Anyone had this happen---mine can't be that rare.
