QUOTE(nycchef @ Sep 5 2008, 07:13 PM)
let me see if i inderstand this. the metal plates are a backstop , as you screw in the bolts the hub will push forward?
Yes, exactly zactly breath...
Rich
so providing i pull this off, literally, should i assume that after installing the washer and the new seal the hub will just slide baqck on?
Yes, its a tapered fit that gets held in with the single bolt.
You can heat it to expand it a bit, but I have never needed to do that.
I cant remember the torque specs, but you really dont want to go over that spec...its a threaded hold in the end of the crankshaft.. not cool to futz up.
There is also a key, dont loose it.
Rich
