QUOTE(r_towle @ Sep 5 2008, 05:40 PM)
inner fender to inside of rubber tire.
Inner fender to outside of rubber tire.
What wheels? Backspace? How tall?
Rear:
With the cookie cutters and the 9" slicks i use a ~3/4" spacer and i have shaved fender lips and i can't get my finger inbetween the fender and the tire. It's that close.
There's just enough space on the inside for the tire to move with the suspension. 1/2", if that. No rubbing.
Front:
With the cookie cutters and the 9" slicks i use a ~1/4" spacer and i can barely get my finger inbetween the fender and the tire.
There's just enough space on the inside for the tire to clear the shock, but only after i cut down the housing sleeve (still using the top as a large washer).
With the shock housing in place, the tire was too wide.
I run 100mm wheel studs front/rear and full late model 911 hubs in the front.
Andy
