Hi,
as I said in my introduction, I want to get racing seats (Recaro SPG) in my 914.
Figured out that it will be easy to use the original seat rails together with a slightly reworked adapterplate.
As advised in several threads here the harness will be boltet directly to the firewall directly behind the seats in the height of the holes in the seats.
I intend to use eye bolts and snap-on brackets on the harness.
Problem now is the space behind the seats. Eye bolts and snap-on brackets will at least use 6-8cm (3 inch). Then there is the belt with the 3 bar slide for reducing the length.
Where to place all this crap? I got to put my seat nearly to the firewall (6'2" tall)
And I belive that there should be slight extend of the belt before it goes through the seat to my shoulders.
Where have you all this belt overlenght? How much space do you have behind your seats? Are there regulations how much belt lenght to have between seat and bracket?
Do you have pictures of your car/seats?
Regards
Marc
