DNHunt
Feb 4 2004, 09:05 PM
Rhodyguy brought his car by to repair the damage caused by the ass that stole his car last summer. The right side of the trunk was elevated because the pivot was torn loose.
I supplied the welder, he supplied the labor. Sure is nice to watch someone else work. It was a real bitch for Kevin to access and see with the engine in but, he got it stuck real good.
DNHunt
Feb 4 2004, 09:08 PM
He had to get all twisted up. I'm betting he's kind of sore tonight.
DNHunt
Feb 4 2004, 09:11 PM
It actually ripped one spot weld out of the inner wheel well so we had to repair that first.
DNHunt
Feb 4 2004, 09:13 PM
More twisting. Oh my achin back
DNHunt
Feb 4 2004, 09:17 PM
A successful finish. Even gaps
seanery
Feb 4 2004, 09:18 PM
what's up with the California license plate?
Jeroen
Feb 4 2004, 09:35 PM
QUOTE(DNHunt @ Feb 5 2004, 04:13 AM)
That's a funny pic!
Looks like you're holding him by his feet and he's dangling above the engine compartment
Have a beer on a job well done
cheers,
Jeroen
rezron
Feb 4 2004, 10:23 PM
Has anybody here ever welded a small piece of
angleiron under the hinge pivot? I had someone
recommend it to me and it worked well and I doubt
that it'll ever tear loose again!
rezron
Bleyseng
Feb 4 2004, 10:30 PM
I suppose you could but the damn things either tear out the center part or rip themselves off the inner fender.
I get spooked welding over carbs/FI without a blanket. All that gas is there.
Geoff
Porsche Rescue
Feb 4 2004, 10:47 PM
Kevin's car is an import from the south. Bet it came to him with that fine plate.
Qarl
Feb 4 2004, 11:02 PM
Looks like you had fun!!!
Joseph Mills
Feb 4 2004, 11:12 PM
Get OUT of here Ol'Dude! I don't want my rear window washed. I ain't givin'you a nickel.
Bruce Allert
Feb 4 2004, 11:48 PM
Hey! good job guys... I did mine and, YA, it was a bitch
I wasn't so lucky with getting the trunk to fit as good as your Kev. Mine's still a wee bit high in one area.
.........b
rhodyguy
Feb 5 2004, 07:38 AM
thanks again dave!! def a job when the engine is out if you need it done. if you were to use a piece of flat stock you would have to put it inside the wheel well or the hinge pivot would be pushed in board. my guess is the compoment (welded hinge bracket) is the weak link. over stressing it, like the engine cover bracket, tears them out. the bracket i removed was ready to go south. i caught it in the nick of time. i'm very pleased with the end result.
kevin
DNHunt
Feb 5 2004, 07:51 AM
Kevin
How are you feeling this morning?
The pictures don't do justice to the positions you got into. Several times I could see you shaking from fatigue. You and I suffer from the same problem. DAMN BIFOCALS It's really hard to get the right distance to see things well. Anyway, Kevin remember what the Gais Brother's bakery used to say. "Slow welders but fast drivers". KICK ASS
Dave
rhodyguy
Feb 5 2004, 08:06 AM
dave, i don't feel bad at all aside for a 20 y.o. mind in a 51 y.o. body. you're right, working in a fixed position, with your head upside down, looking through a welding hood and fighting the line in your bifocals, does'nt make things easier.
kevin
DuckRyder
Feb 5 2004, 08:57 AM
QUOTE(Bleyseng @ Feb 5 2004, 12:30 AM)
Geoff
That is what I was thinking..........
Bleyseng
Feb 5 2004, 09:22 AM
Hey Guys, most welding shops sell the plastic small goggles in reading strenghts. Fit right inside the helmets too. Makes it way freakin easier.
Geoff
Air_Cooled_Nut
Feb 5 2004, 11:44 AM
I have to make the same repair, good to know it can be done with the engine in the car. However, due to far too many oil leaks (and simply for the experience) I will be dropping my motor. I guess while the motor is out I should patch the battery rust HOLES
Brad Roberts
Feb 5 2004, 08:31 PM
For those reading along at home... this is a easy fix with a injected car. The carbs ar not in the way.
B
