klikkid3
Sep 15 2008, 06:21 PM
Hi there, so I got sick of having a non operational brake warning light and that constant clicking noise when I get up to speed. The tech guide blames the reset switch on the Master Cylinder. I get underneath to hit the switch and no switch. Went back to the tech guide and it says on MC like mine the switch needs to be reset from behind. When I pulled the switch there is what looks like a plastic plunger handle that can move in and out. I went for broke and just made sure it was able to move and it does and put the switch back in. Ofcourse that didnt do it. So how do I reset the switch from behind?
Thanks
Phill
RoadGlue
Sep 15 2008, 07:49 PM
Hi!
Just fully unscrew the sensor that's on the master cylinder and then screw it back in. That should reset it.
majkos
Sep 15 2008, 09:02 PM
THANK-YOU!
been trying to figure out how to reset myself!
KELTY360
Sep 15 2008, 09:11 PM
Me too! Thanks.
r_towle
Sep 15 2008, 09:14 PM
There is a big red button right next to the master...
hard to describe....let me see if I can find a pic.......
here it is
nsr-jamie
Sep 16 2008, 04:58 AM
Is that the problem with the clicking sound that never goes away?? I thought it had something to do with my Ebrake? The red light goes on and off when I use the parking brake but the clicking sound never ever stops....I am going to reset mine the next time I have it on the lift. thanks
klikkid3
Sep 17 2008, 02:15 AM
Well I am glad there are others out there that this could help, sadly for me the clicking remains and the e brake light stays unlit. I have bled the front brakes but never the back. I have good brake pressure but I wonder if that would stop the clicking?
klikkid3
QUOTE(r_towle @ Sep 15 2008, 08:14 PM)
here it is
Maybe its in german thats why I cant find that button.
majkos
Sep 27 2008, 12:48 PM
ok, I reset the brake button, now I have a faint flashing vs bright flashing I had earlier.
is this normal?
r_towle
Sep 27 2008, 02:31 PM
QUOTE(klikkid3 @ Sep 17 2008, 04:15 AM)
here it is
My bad...the button says einfach.
Rich
southernmost914
Sep 27 2008, 02:42 PM
The brake warning light relay is a multi-purpose relay and is also used in your turns, hazards ect. When this relay starts to fail strange things can happen. Try a with a new relay.
Steve
majkos
Sep 27 2008, 03:24 PM
That's sounds about right, I've notice I've some weird problems and 'it's all seem to be pointing to a ground issue. (Rear taillights)
I've also switch the wires around on the brake sensor, no more flashing light.
I didn't think this would solve the problem for very long, so switched back.
At least I can button up the front end and take her out for a run.
Dave_Darling
Sep 27 2008, 10:54 PM
The switch just grounds the brown/yellow (brown/white?) wire that plugs into it. The ground is provided by the brown wire that plugs into it. Switching the wires "should" not have any effect...
--DD
klikkid3
Sep 28 2008, 12:10 PM
Just a quick update, so I am a little embarrassed to say but the clicking was the air catching the vinly on the dash by the defrost vent
, dont have the foam piece for it yet. So that is solved but I still dont have the light working.
