QUOTE(jcd914 @ Sep 16 2008, 01:57 AM)
at roughly 30 degree angles
30 degrees is not possible without bending something.
Are you having trouble with tire wear?
OK someone will probably disagree with me here but that is OK.
-1 degree 30 minutes (-1 1/2 degrees) rear camber will not really cause a lot of tire wear if the toe is set conservatively, maybe a 1/16" toe in on each side. It is the combination of a lot of camber and too much toe that eats up the rear tire (fronts for that matter). I have set a lot of Porsche's up with close to -2 degrees of camber with big wear issues. If all you are going to do is drive straight down the road then you don't need any camber but if you want to corner occasionally it is worth the extra wear.
Jim
30 might be a bit much. It was a guess. They are very aggressive looking tho.
I like the setup for AX but tire wear is a concern on the road. It is not my DD but it is driven a lot.
Thx for the good info Jim
jkp
