QUOTE(Cloudbuster @ Feb 5 2004, 12:55 PM)
How is it easier?
I think roof un/stowing would be a little easier because you don't need to lift the roof over the decklid. Just tilt the front and swing up. (You could even get the milled sunvisor brackets made with built-in pulleys and run some block-and-tackle system to pull the roof up, without even having to get out of the car!)
Even better, if the decklid hinges at the back, you can climb into the trunk area and easily reach the middle of the engine bay, or get both hands comfortably down into the lower corners. (I got very frustrated trying to remove the ECU bracket one-handed).
now you lost me. you lift the roof OVER the rear trunk lid?
why in heavens do you do that?
the way the lid is stored in the trunk right now, you need
to have access from the rear as you slide the top into the
holders first, than secure it with the rubber fasteners.
i can't imagine how one would do that with the rear trunk lid
opening in the front instead of the back.
climbing into the trunk to work on the engine?
if you know you're going to work on the engine and you anticipate
clearance problems, why not just take the engine lid OFF?
takes about 2 minutes (2 10mm bolts) and unless you're 4'10" you should be able to access anything in that engine comp ...
Andy
