QUOTE(TC 914-8 @ Sep 18 2008, 08:02 PM)
QUOTE(9146986 @ Sep 18 2008, 07:14 AM)
I haven't seen it myself, but Brad Mayeur had told me that LSD transmissions have/had an aluminum tag under one of the nuts for the side cover.
well I would figure being 32 years old my tag is gone. is there a stamping or other designation that would be a way of ID a LSD.
I have just dumped the clutch (in 2nd gear) and both tires light up.
You gota love V-8 power.
Tony
If you see HB on the bottom rib of the case it is, or was a ltd. slip. I just got that info myself.
With both rear wheels off the ground in neutral hand brake off, spin one wheel, if the other wheel goes in the same direction it is a ltd. slip. If it goes in the other direction it is a standard diff.
Rory
