QUOTE(mambodave @ Sep 19 2008, 01:08 PM)
hum...ok now you got me thinking... so with my 1.7 case... what would i need to make that a 2.2 or go for it to a 2.4? heads and pistons? Am i safe to assume my 35 year old heads should not be used, but buy new..
after reading though I belive I can tear it down and build one myself, with a little help. So I guess that expands the canvas...
Depending on the specific size that you want, you'll need pistons/cylinders, a stroked crank, clearanced rods, and other supporting parts... you don't want to put a stock camshaft into a big engine.
You can use your case, but you'll either need machine work on the heads or a set of 1.8 or 2.0 heads to get a 2.2-2.4. If you are going to go big, you'll be spending money, so you'd be best off having the head rebuilt, or just buy a good new set from Jake. Most builders agree that you don't want to go bigger than 96mm bore with iron cylinders.
I can't afford a Raby kit right now, so I'm collecting parts as I find them to build a 2258. I'm hoping to save a couple thousand $$$, but I also don't expect to get the results that Jake can produce, and I won't have Jake standing behind the engine. If you have time, are willing to keep your eyes open, and willing to take the risk and responsibility, you might be able to do what I am attempting. Otherwise, talk to Jake about a kit.
Here's what I've got so far:
78mm crank - $100.00
WebCam #163 with timing gear - $76.01
dual valve springs - $22.75
new pushrod tubes - $22.00
complete 2.0 core engine $300.00
complete 2.0 core engine with Weber 44 IDFs $400.00
set of 1.7 rockers $40.00
I also have a set of clearanced rods that I won't be using... I don't see how they will work with a 78mm stroke and a 24mm piston pin. My crank has stock 2.0 rod journals, which is not ideal for a stroked Type IV, but it "saved" me over $400.
I'm looking into the possibility of having the journals ground to fit another rod, but I doubt that it is feasible... the 2.0 journal is smaller than most other rod journals.
I am taking the risk myself. I may fail, but I don't think that I will. I'll have fun though.
