QUOTE(LetoAtreides @ Sep 18 2008, 11:51 AM)
I've been having issues with my transmission. It has been leaking a little bit of fluid, so I'm wondering if that's turned into a big problem. I have a really tough time trying to shift into first. Most of the time it just slips into third, and so, there I am trying to fight the stick while at the stop light. I've also found it difficult to find second gear. Does this mean that I have to rebuild the transmission (very difficult when one lives in a dorm)? What kind of tool do I need to unscrew the filler plug on the transmission so I can change my fluid?
First check is the cone screws. Make sure they haven't backed out a little. This will cause sloppy shifting. Your shifter bushings at the firewall and at the console at the transmission may need replacing. A 17mm wrench for the oil drain and fill plugs.
