QUOTE(chcjr @ Sep 19 2008, 10:06 AM)
Is removing the cooling fan and housing difficult?
Yes or no depending on what you call difficult and your mechanical ability. my understanding of the a/c system in a 914 would require that the belt be looped over the fan (a/c pulley is on crank behind the fan) onto the a/c pulley then fed behind the fan housing to loop on the compressor pulley. not easy (at least it wouldn't be for me) working thru the engine compartment lid. i wonder if it would be easier/faster to drop the engine (incredible as it sounds) to replace the belt only for the convenience of access to the area, i don't think you have to remove the fan or fan housing. just loosen the compressor tension bolt/nuts, belt over cooling fan to a/c pulley, feed belt thru housing to compressor pulley, over pulley, tension belt with bolts/nut. surely the good Cap'n has done this and will contribute his answer.
