OK, I thought of something else I might want to do now that the car is basically totally disassembled. How do you guys feel about replacing the plastic fuel lines that run from the front "fire wall" to the engine compartment thru the passenger compartment. Mind you, my car has no fuel tank, no interior, no engine and transmission, no wiring harness - hell its just a tub. I have removed the access panel and can see the two lines running down the middle of the car. Also, does someone make up the replacements in stainless steel? Might as well do this now. Ideas, experiences?
