QUOTE(Cevan @ Sep 22 2008, 05:16 PM)
If you're talking about reconnecting the e-brake cable, I didn't have to remove the calipers to do that. There is an adjustment nut where the cables exit the firewall. You could turn them all the way in to give you the most slack in the cable and then re-adjust them once the cables are connected.
thanks that sounds easy enough
rich
