QUOTE(Richard Casto @ Sep 23 2008, 10:29 PM)
There are two lines in PET with the same part number. I missed that they had the same number and was focusing on the second one. I had looked at the first and figured "hydropneumatic" because of the weird spring thing, it was Boge (creator of the hydropneumatic strut) and it was listed as used on 911E (only car that had the hydropneumatic strut??). I am confused as to why the second line has the same part number, but says Koni and 72-73.
I know that hydropneumatic a-arms are junk (no way to use torsion bars), but I wonder if it possible that you can remove the guts from the strut, use a Koni insert and with the correct gland nut make a working strut? If so, I wonder if maybe Porsche had some stock left over from the 911E mess and used some of those struts in 72-73 but with Koni inserts???
(Mike, beware that I am making this up as I go and at this point just curious as to why PET lists what it does the way it does. Rich/ArtechnikA is probably right)
well - my PET doesn't have two identical part numbers, so clearly there's -some- confusion ;-)...
a 901.341.084.10 is indeed a right-side '72+ S (3,5" brake saddle..) Koni strut.
(the confusingly similar 901.341.084.01 is the Hydropneumatic.)
Okay - so a .10 is *not* junk as long as you like Koni dampers.
I donno if you could use a hydropneumatic for any other kind of coilover.
I -thought- the HP struts also had 3,5" brake saddles because I thought E's had aluminum calipers (originally) but I'm pretty fuzzy on that. I do believe (perhaps mistakenly, but it's my current belief...) they had S calipers because I recall several sets of them being sold off by 'E' owners who had to somehow finance a new set of A-Arms, torsion bars, and dampers when the OEM HP stuff shat the bed...
But this is another reason why E's typically have no antiroll bars - the HP spring/dampers had a rising rate and therefore progressive antiroll characteristics. One more thing E owners hadda go buy to bring the cars up to the S spec they shouldda bought originally ;-)...
I've attached my PET picture with part numbers - I'd love to see one that shows multiple parts with the same number...
