QUOTE(Mark Henry @ Sep 23 2008, 10:03 PM)
...might be a tad hard to attach your wheels to a car without stub axels
It's not - tho - the hubs will stay in for a little while...
( FWIW - I knew what you meant, but I felt an expansion was appropriate due to the volume of new owners. The 'experienced guys' can gloss over a few "assumed" steps but the beginners are reading these threads literally... )
responding to the other posts...
Remember the halfshafts turn at wheel speed, which is maybe 1000 rpm. You do not want to see what happens to the undercarriage when a halfshaft goes flailing around at 1000 rpm. I don't think I'd trust bungies to be a bearing.
it -should- be as easy as pull the cotter pin, use an impact wrench and 30mm socket to loosen the big nut, and withdraw from the inside. Sometimes they will get stuck, especially if the PO didn't assemble them with antisieze... put the nut back on inverted (castellations in) to no more than flush with the end of the stub axle shaft, and tap only as much as needed with a brass or bronze hammer to loosen.
Then you can remove the 12-point "triple-square" CV bolts with the halfshaft clamped comfortably between the soft jaws of a vise.
