QUOTE(AvalonFal @ Sep 25 2008, 06:37 AM)
QUOTE(roadster fan @ Sep 24 2008, 06:54 PM)
Umm, the drop links that came off my 73 have a slight angle in each on one end. I think it is so they don't bind. I will try to get a pic of what I am talking about.
Jim
Jim, that's the same as on my '74. Is the angle at the link top or bottom when installed? Or do we both have bent links??
Paul
Top I think. It makes sense on the stock setup based on the way the u-bracket on the a-arm is fixed.
Joe makes a good point about the spherical bearing setup the racers use. I am gonna upgrade mine I think instead of installing the stock. Then you can adjust for preload.
Jim
