QUOTE(Cap'n Krusty @ Sep 24 2008, 11:56 AM)
I've been setting end play on VW and Porsche motors since 1970, and I've never heard anyone suggest you have to remove the distributor drive pinion. Not even at Porsche school. Why would you ever do that? As long as you don't turn the motor upside down, what can possibly happen?
The Cap'n
Actually 2 reasons. first, the crank gear is designed to turn the pinion when the crank rotates, not when the crank is pushed back and forth, which could be as much as a 1/4" if not more when the flywheel is not on.
Second, you will get better readings when trying to set the end play.
You want to try something ? Mock up a crank in a case half, move it back and forth, then put in a drive pinion, then push the crank back and forth again, if you decide to try it, let me know what you find out.
Oh, and since the motor is almost upside down you will have to put on the dist clamp to hoild the dist so the pinion doesn't fall out...
