mattp
Sep 24 2008, 01:47 PM
Can someone send me a pic of a throttle pedal stop?
Bartlett 914
Sep 24 2008, 02:10 PM
Here you go.
mattp
Sep 25 2008, 09:46 PM
thanks, can you take it from further out? I need to see where to position it. thanks, matt
BMartin914
Sep 26 2008, 08:36 AM
You need to set the "Full Throttle Stop" at Full Throttle travel of the pedal/cable.
It does not have a preset position.
You need to have a helper open the throttle body on the engine to full throttle (with the stop threaded IN) and then move it out to meet the pedal in it's "Full Throttle Position."
Do you have a Haynes manual yet?
Bartlett 914
Sep 26 2008, 08:39 AM
That is the stop directly behind the pedal. The threaded plate is a part of the pedal board. The white plastic stop may be missing but the plate must be there. Look behind your accelerator pedal an see if it is there. If it is missing ask on the parts section. Should be plenty around and real cheap.
mattp
Sep 26 2008, 09:17 AM
i got one, there is no pedal stop at all on my board. i need apic so i can tell where to put this one. matt
Bartlett 914
Sep 26 2008, 10:48 AM
QUOTE(mattp @ Sep 26 2008, 09:17 AM)
i got one,
Got one what? The steel threaded plate? That must be there is it not?. The white plastic screw is the adjustable stop.
mattp
Sep 26 2008, 03:55 PM
there is nothing on the pedal board but I have a used pedal stop i good shape, its the metal base and the plastic bolt. I just need to knowwhere to place the metal base. matt
Bartlett 914
Sep 26 2008, 05:46 PM
QUOTE(mattp @ Sep 26 2008, 03:55 PM)
I'll get you a pic tomorrow. Do you have a stock pedal board? If is is a stock one, then the plate should be there or the holes should be.
Bartlett 914
Sep 27 2008, 01:04 PM
Last one
