QUOTE(Cap'n Krusty @ Sep 28 2008, 12:06 PM)
My first employment at an independent shop was At Porschop in LA. The bosses were well known innovators and "fixers" rather than parts changers. We did a side shift conversion in 1974. Vern Covert made a flange for the boot by welding tabs on an old 356 rear main bearing (cut in half) and affixed it to the firewall. The boot slipped right over it. If you can TIG weld, I think I can supply you with a used bearing.
The Cap'n
So the fix is to make a flange like a 74...ok we can do that while the tub is stripped for Rockets new car...
I may be able to just remove the flange on his car...gotta go take a look.
I like having that boot, it keeps the cone screw from falling on the street...
Also keeps the lube in there.
I can make a flange or like you said, use a bearing...I have a few.
I was hoping someone came up with a simple boot from some other car that worked...oh well.
Rich
