You recommended some time back that I switch from multi-viscosity oil to single in order to cut down some on the oil burning problem ... and I'll be damned if it hasn't made a noticeable difference! It does still burn some - it's not like the problem was magically solved or anything - but it's definitely better than it was.
Also, you had mentioned wanting to possibly make a poster from one of the 914 pictures I posted - the 9 repeating images, if I recall correctly? That's certainly ok by me. Let me see how good a scan I can get out of it, and I'll send it to you on disc if you still want it.
