I'm working on a project that has cable railing and the client has decided to utilize another type of railing on some upper decks. I have 18 posts left over that are pre drilled for 12 cables. The overall post height is 37" without any type of top cap. I can provide a top rail or you can use a nice hard wood like Ipe to attach as a top cap into the existing screw races.
These will bolt to the deck surface using 3/8" lag screws on a 5"x5"x 3/8" base plate, I can assist in determining layout if you need a hand.
These posts are finished in silver metallic Duranar XL. Not just a powder coat. This is best finish available for salt air exposure.
http://corporateportal.ppg.com/NR/rdonlyre...0/DuranarXL.pdfI have 18 posts pre- drilled all the way through, and 4 corner or end posts that are drilled on one side.
You can use 1/8" to 3/16" cable the way they are set up. You can obtain cable locally, or I can provide.
I'm asking $50 each these would retail for over $95 each. Open to offers, prefer to sell as close to a package as possible. Should be able to ship UPS Ground pretty inexpensively.
See some of my projects using this type of product at
DIYRailing.com
Thanks,
Mark
