QUOTE(turnaround89 @ Sep 30 2008, 12:50 PM)
Explain how to relay it directly to the battery, i am ok with simple wiring but adding relays is where i get lost?
If you want to add a relay, here's a simple explanation:
Relay has 4 connections:
2 for the relay contacts: With 12V on the coil, the contacts close to make a connection from one contact to the other; with 0V on the coil the contacts open circuit
2 for the coil. Connect to 12V and the contacts close. 0V and contacts are open.
To rewire the +12V on your radio, run a heavy wire from the battery +12V through a fuse (in-line glass fuse or equivalent; probably 15A), other side of fuse goes to one relay contact.
Other relay contact goes to radio +12V.
One side of coil goes to ground. Any chassis connection will work.
Other side of coil goes to switched 12V that used to power the radio.
Done.
I suspect that the reason the CD turns off is there's some dirt or oxidation in the wiring, fuses, or, connectors behind the fuses, or grounds causing resistive voltage drop when lights+pop-up motors turn on.
Try this test:
When you turn on your lights, the pop-up motors also run causing heavier load than just the lights. Turn on lights to pop-up the lights, then back down to parking lights. Then turn on CD then turn on lights to see if just the lights going on causes the CD to stall.
If I were you, I would clean all electrical connections first before adding the relay:
1) disconnect battery NEG
2) drop relay panel
3) There's a 12V lug behind the relay panel where several heavy wires connect; remove lug and clean connectors with fine sandpaper; spray with contact cleaner; replace connectors & tighten lug.
4) Remove all fuses and clean contacts with fine sandpaper; spray with contact cleaner; including contacts on the relay panel.
5) On the back of the relay panel, remove wires from push-on spades ONE-AT-A-TIME and clean the spades and the connectors with fine sandpaper; spray with contact cleaner; and replace.
6) replace relay panel
7) Find all ground connections, remove wires and clean with fine sandpaper; spray with contact cleaner; replace connections.
8) disconnect & clean battery POS and reconnect
9) clean and reconnect battery NEG
10) Put on some Metallica, enjoy the music and
