For sale misc. items. (Pics start in 2nd post & may or may not be actual)
If you don’t see some thing you’re after, ask there's a good chance I have it.
If you want something and feel the need to dicker, make offer. Trades welcome.
I’m liquidating all the stuff horded for my restoration, but left over,
so I have a lot of bits and pieces. All parts are for /4 unless otherwise noted.
All prices quoted less actual shipping/handling.
(International sales via Fedex 100% shipping & item prepay only!)
Because the majority of these items are for small $’s, Check, MO or buyer covers the PayPal fees
(better yet check into
POPMoney ).
Shipping can be combined on multiple items but in doing so *please* be patient,
it can take some time to adequately pack the selection to avoid damage.
Check back often, as things get snapped up Ill add more!
#1 Tinted Door Glass $9.14 SOLD#2 Tinted Vent Glass (Triangles) pair. $20.00
SOLDHi Rich
#184
Last time I looked for this you offered a piece that was much more than I need. Thanks for responding
Please confirm that it looks as good on the inside as it does on the outside.
If so, I'm ready
I'm at 07652 I've had good luck with USPS
Thank you
Rory
Please just confirm that it is clear and clean on the inside
#3 Wiper motor & linkage assembly
$65.00 #4
R. bolt in sway bar brackets $9.14 SOLD#5 License plate brackets (each, F. or R. early or late) $9.14 SOLD#6
Center Deposit Tray $9.14#7 Fresh air blower motor
$35.00#8 Fresh air blower box & motor
$50.00#9 Fresh air controls (late)
$45.00#10 Lightened (11.5lbs) Flywheel, PP & disc (gently used) $140.00 SOLD#11 Pressure Plate & 4 spring clutch disk $75.00 SOLD#12 Gauge Bezel (metal)
$15.00#13
Headlight surround (white early) single $9.14#14
Headlight surround (black late) each $9.14#15 Late window regulators R or L
$30.00#16 OE late tie rods (screw vs pinch) pair
15.00#17
R. Trunk spring bars (pair) $9.14#18 Steering Rack (w/o shaft)
$35.00#19 Gravel shields (each)
$25.00#20
Headlight covers (pair) $9.14#21
Headlight Eyebrows (pair) $9.14#22
Used 1.8 Piston set $9.14 SOLD#23
Used 94mm Piston set (2.0L) $50.00 SOLD#24
Targa Top storage Brackets (forward) per $9.14#25 OE shifter (early or late)
$30.00#26 Gauge Cluster complete (early 120MPH)
$80.00#27 Speedo's (early & late 150MPH only) $20.00 SOLD#28 Fuel/Combo guages (early & late)
$20.00 #29 Front hood (PU only)
$75.00#30
Shift boot (rubber) $9.14#31
F. turn signal lenses (pair, used cond.) $9.14#32 F. turn signal buckets (per)
$15.00#33 A. pillar trim (per side)
$15.00#34
B. Pillar trim (per side) $9.14#35 Front brakes (each)
$15.00#36 Rear Brakes (Pair)
$45.00#37
Headlight relay cover (black) pair $9.14#38 Eng. Lid Grill (per)
$20.00#39 Exhaust tip w/bung
$25.00#40 Speaker pods each
$20.00 #41 Retractable (late) seat belt set
$45.00 #42
Seat belt latch whip (late) per $9.14#43
Seat belt latch whip (early) per $9.14#44 Front hood latch set
$20.00 #45 Rear Deck latch set
$20.00#46 Horn set (late, pair)
$25.00#47
Black 1.7 script $9.14#48 Round relays (black) each
$4.00#49 Black door panel set (75-76 weave w/speakers) $75.00 SOLD#50
Chrome headlight trim rings (pair) $9.14#51 OE Blk headlight trim rings (pair)
$15.00#52 Pass. Rear .25 panel $50.00 SOLD#53 Drvrs. Rear .25 panel $50.00 SOLD#54 Set of decent tires (90%) 165x15 $35.00 SOLD#55 Steering column 75-76 /4 (w/ign & key) $50.00 SOLD#56 Early Metal door latch bezels (pair) $25.00 SOLD#57 Early Window Cranks (pair) $15.00 SOLD#58 Side marker assemblies w/Lens (per side)
$30.00#59 Headlight Bucket assemblies (restored complete pair)
$125.00#60 Rear US lens (average shape. per.)
$50.00#61
Late /4 Boge strut housings (each) $9.14#62
Trans Ground strap $9.14#63
Bumper Dog bones (pair) $9.14#64 1.8L FI harness (w/ injectors) $60.00 SOLD#65 2.0L 912 Fuel Injectors (set of 4) $35.00 SOLD#66 Glove box door /4 73-74 vinyl
$20.00#67 Cam Gear
$15.00#68
Screw in Studs w/nuts (per)$1.00#69 Transmission or early eng. mounts (NO cracks) Per.
$15.00#70 OE Valve covers Per.
$10.00#71 Alloy wheel lug bolts (Per.)
$5.00#72
Trunk Steel knockouts per $9.14 #73
Headlight bucket support steel per $9.14 #74 Aluminum Door thresholds (early, pair) $25.00 SOLD#75 Black Plastic Door thresholds (late, pair)
$20.00#76 Interior Trim Plug set (all necessary to finish) $15.00 SOLD#77 OE rear view mirror (early) $50.00 SOLD#78 Leather Wheel Wrap $9.14 SOLD#79 Transmission Mount assemblies (complete pair)
$40.00#80 Complete wire loom (uncut) 72MY
$75.00#81 Aluminum Door *fuzzy* guides (pair) $20.00 SOLD#82 Brake fluid reservoir assembly (w/lines)
$35.00#83 Cabin Fresh air vents (per) $9.14 SOLD#84 Fuel Tank assembly (early or late)
$100.00#85 Quad Tip Muffler (1.7-1.8L) $40.00 SOLD#86 1.7-1.8L OE HE's (Good condition!) $40.00 SOLD#87 Rain tray (late)
$30.00#88 Carb Fuel Pump $20.00 SOLD#89 Holly fuel regulator (carb?)
$20.00#90 Aluminum Trunk rollers $9.14 SOLD#91 OE Shift knob
$35.00#92
Steering rack bellows $9.14#93 Turbo Tie rod ends $30.00 SOLD#94 Windshield (local PU only) $75.00 SOLD#95 Lower dash pad(s) w/vents
$25.00#96 Lower dash pad (early no vents)
$30.00#97 Engine mount bar (Late sideshift)
$30.00#98 R. rubber bumper top (nice shape) $50.00 SOLD#99 Heater fan outlet (Dual) $20.00 SOLD#100
Heater fan outlet (single) $9.14#101 Rear rubber bumper top (Very nice!) $85.00 SOLD#102 BMW 320i calipers (REBUILT & PAINTED) $125.00 SOLD#103 Period Blau AM radio $50.00 SOLD#104 Steelie Hub Cap set (good shape) $50.00 SOLD#105 Period Sapphire AM/FM radio w/ NOS faceplate $60.00 SOLD#106 Rain Tray Drain Tubes (pair)
$20.00#107 Impeller Fan (late, all fins intact)
$30.00#108 Heat Flapper valves (L or R)
$25.00#109 1.7 or 1.8 OE chrome muffler tip $9.14 SOLD#110 OE Flywheel (fresh machining)$100.00 SOLD#111 Bursch Muffler for all late 75-76 HE's (w/bypass pipe) $150.00 SOLD#112
Muffler hanger for late 1.8 or 2.0L $9.14#113 OE Muffler for 73-74 2.0L (Banana, VERY nice!) $250.00 SOLD#114 Rear Trailing arm hubs (pair /4)
$20.00#115 Rear Trunk replacement steel panel $120.00 SOLD#116 1.7 Throttle body & TPS $35.00 SOLD#117 Center Deposit box (early) $35.00 SOLD#118 Thermostat assembly (complete) $65.00 SOLD#119
F. hood springs (pair) $9.14#120 Map Pocket (Black)
$25.00#121 1.7L pre-heater tin assembly (rare!)
$35.00#122
Heat vents (Cabin under dash pair) $9.14#123 Door latch assemblies (Int. pair)
$35.00#124
Door latch assemblies (Ext. per) $9.14#125
Longitudinal tar long plugs (set of 4) $9.14#126 "73" 2.0L FI D-Jet Brain $45.00 SOLD#127
OE Trunk spring rollers (plastic) $9.14#128 R. Tail panel section
$60.00#129 Windshield washer res. bottle (w/lines)
$20.00#130 .5 shafts (pair)
$50.00#131 Tank latch set
$15.00#132 Cabin access cover set
$20.00#133 Motor mount brackets (pair late)
$35.00#134
Fresh air valves (R or L per) $9.14#135
Defrost Vent (R or L per) $9.14#136 Insulted Long. heat tube (Pair, ok cond.)
$20.00#137 Tail shift shift-rod cover (front) $20.00 SOLD#138 Targa top complete w/hardware
$75.00#139 Body plug set (front)
$30.00#140 E-Brake handle assembly (late)
$45.00#141 Seats, (Pair) late basket-weave cushions $150.00 SOLD#142 Shift knob, leather & crest
$30.00#143 Exterior Door handles (no lock cyl.)
$50.00#144 Polyurethane Front bushings set (NOS 4 A-arms) $20.00 SOLD#145 Eng. Bay Relay board (average cond.)
$25.00#146
Various Engine tin. per piece. (no 2.0L top) $9.14#147 Side shift conversion parts (All, no trans-axle)
$150.00#148 Side shift trans-axle
$250.00#149 Pass. Ext. Suspension console $55.00 SOLD#150 Engine Case
$75.00#151 Muffler hanger for early 1.7 or 1.8L $9.14 SOLD#152
Headlight Eyebrows grommets (set of 6) $9.14#153 GT Engine Lid $125.00 SOLD#154 Weltmeister A-Arm tab kit (NOS)$20.00 SOLD#155 Flag Mirrors (pair) $9.14 SOLD#156 Console heater lever (w/knob)
$30.00#157
Carpet Pieces (per)$9.14#158 Dash switch set $55.00 SOLD#159 Exterior Mirror (w/pad & screws)$50.00 SOLD#160 Muffler Heat Shield
$30.00#161 Koni Red rears shocks w/progressive springs $125.00 SOLD#162 Fresh air box plastic grate
$20.00#163 Complete fresh air box assembly $100.00 SOLD#164 Rebuilt Pedal cluster
$100.00 #165 901 transaxle tool (shaft or 1st/R. slider) $20.00 SOLD #166 Front suspension PU
$35.00#167 Impeller to air inj. pulley mnt. $40.00 SOLD#168 Tachometer gauge (early or late) $25.00 SOLD#169 Defrost R. Window Glass
$50.00#170 Front trunk floor section (AC repair) $60.00 SOLD#171 Formed Glove box (w/strap) $20.00 SOLD#172 Engine Windage tray/oil PU
$30.00#173 1.7L injectors (serviced by Witchhunter) $125.00 SOLD#174 1.7L D-Jet FI harness
$40.00#175 Eng. Shroud flap assembly
$35.00#176 2.0L Rods (set of 4)
$70.00#177 OE Front steel valance
$75.00#178 Riviera wheels (set of 4) $100.00 SOLD#179 Empi wheels (set of 4) $140.00 SOLD#180 Style Steel wheels (set of 4 w/good rubber & caps) $175.00 SOLD#181 901 gear sets (inquire)
$75.00#182 901 syncro rings (Good used, per)
$30.00#183 Air injection "spider" pipe
$35.00#184 Pass. (Int.) R. Suspension console
$80.00#185 Drivers door panel (blk.)
$60.00#186 D-Jet Fuel Injection Pkg (76MY)
$400.00#187 Center tunnel (complete with all tubes intact)
$150.00#188 Late bumpers (75-76) per
$40.00#189 Seat cores (one pair, disassembled & boxed)
$50.00#190 Brake rotor set (used F. & R. w/ fresh turn)
$80.00#191 OE Rear steel valance
$100.00#192 Heater fan (eng. bay Late)
$25.00#193 Targa top latches (Frt. & R)
$30.00#194 Air diverters (eng. bay, pair)
$30.00#195 Washer switch (early /4 & /6)
$20.00#196 Speedometer angle drive
$35.00#197 Fresh air hose (plastic, pair)
$20.00#198 Relay board
$25.00#199 Alternator
$40.00#200 Visors (pair)
$80.00#201 Switch, R. window defrost
$15.00#202 Trailing Arm mounts
$35.00#203 Seat adjuster assemblies (per)
$40.00#204 Fog lights (pair, early)
$50.00
