Ok,
I'm thinking I want to look into selling this car and buying a turnkey DD next year. Car is running with the Ford 2.8L V6 in it. Stays cool with the front mounted radiator. Has hard lines under the car. Tires look new but you'll notice there are two different wheels on there. (PO Issue). Engine bay needs to be cleaned up, touched up, etc. There is no battery tray as the battery is in the front trunk.
Car is very solid and ready to go back to a 914 engine/trans combo. Front trunk floor is cut for airflow to the radiator and the airflow vents throught some weird louvers on the hood. I have an extra front and read trunk lid as well as the front trunk floor section from a donor car.
Car will come with 4-lug suspension spares from donor car as well as a complete set of 4-to-5 lug adapters with lugs. Current tranny is a tail shifter and I have a spare one of those as well. I've started on the body work and there's not much else to do. Sand the car again, prime and paint for the most part.
I have to leave for two weeks starting sunday but should have access to the site and email if you have questions.
