QUOTE(Slick914 @ Oct 4 2008, 03:12 PM)
Couple questions from those who have installed these or have the knowledge I lack....
Are there any fuel lines or wires that need to be removed before welding? Hoping they can be avoided without removal.
No wires to be avoided in the longs, there is the main harness that should be covered for the event. Fuel lines are also in the middle tunnel.
Drain the tank and blow out the fuel lines one day prior...then thel the fuel lines air out for a day. Cover the middle tunnel with metal or tin flashing so the sparks to get to anything.
Will the heater hose inside the longs be ok?
That depends on how good you are with a welder.
If you blow through the long due to excessive heat or to much voltage you will get to the heater tube. If you sit to long in that area, you will heat up the metal and could burn the tube...you need to do one weld in that area then move to a different area till it cools.
Is it a weld through primer on the kit or does it need to be sanded first?
I have never had good luck with weld through primer.
Here is what I do. Clean all the paint and glue off. Spray it with weld through primer. Test fit the piece. use a sharpy to mark all the hole onto the original long.
Remove the piece. Grind (use a 3m scrungy on a drill or grinder) just the sharpy marks so you leave as much primer as possible, just get to bare metal where you will weld.
I'm installing on a finished car. Any precautions I need to take to prevent damaging exterior finishes, catching something on fire, etc?
Remove the interior, seat, door panels, back pad etc. all vinyl.
Cover the dashboard and gauges with cardboard.
One stray spark will melt the vinyl..just keep that in mind.
Fire...always a possibility.
Cover the paint around the doors (if its finished) so any welding spatter does not get to the paint.
I use thick cardboard and keep an eye on it while you pause during welding..
The thick stuff may start to burn, but if you watch it, it can be stopped fast enough.
I tried a cotton/canvas tarp and it catches to fast and smolders away..not good.
Plastic will melt.
Cardboard (corrogated) works well enough.
I guess leather would be best or a welding tarp if you want to purchase a few of those.
