QUOTE(sgetsiv @ Oct 4 2008, 03:28 PM)
I installed a set of Triad headers this summer. They went on nicely and the performance is excellent.
Duc, do you have Dave's headers?
Steve
Hi Steve. My car is being converted to a 6, with B&B SS heat exchangers. When I get it back next week, I'll be putting on a Triad exhaust.
Before the swap, with my 2.0L, I was running Dave's performance muffler with 2.0 SSI heat exchangers. Power and torque gain was noticeable compared to the (new) Bursch I had before. There are 3 add'l bonuses w/ the Triad:
1) You get better fuel economy (from better flow, I assume - the exhaust experts here will correct me if I'm wrong). I was seeing 40-50 add'l miles per tank. That's just from changing the exhaust.
2) You get a really sweet exhaust note. It's throaty and purposeful. A lot of people say it sounds like a 911. Compared to my stock '73 911T, I would say it sounds more like a 911, but not necessarily like it exactly. That's not a bad thing, or good. Just my subjective evaluation of the note. It is definitely less VW Bus, rattly sounding than all other options I've tried in the past. IT SOUNDS GREAT! Without being obnoxious. Open it up on a back road, and it'll seduce you.
(Here's a quick clip I found on youtube:
http://www.youtube.com/watch?v=NBf1cpu2A2k )
3) The exhaust wears really well. I was able to look at Dave's wife's car with a 12-yr-old (or is it 15?) Triad, and it looked incredible still. Compare that to something like a Bursch...which will start rusting and looking cruddy in a matter of months; my Bursch was an eyesore after 4 months.
I didn't run headers because I wanted heat. I understand some builders will build you heat boxes for their headers, but Dave @ Triad told me he didn't feel comfortable doing that, as a leak into the heat boxes could be disastrous. It may not be likely...but with steel...welded bends...it could happen.
I was able to look at the Triad headers up close, on a lift, and the workmanship is top-notch! Little details are looked after, like heat shields to protect nearby components and lines. Dave races, so his products benefit from real-world testing and improvement.
For those who may not know, Triad also makes systems for 6-cyl cars.
Sorry to sound like a total Triad fanboy. Just wanted to share my experience.
-duc
